Use this template along with a spring-loaded punch or marker for consistent placement of potentiometers, toggle switches, LEDs, and footswitches on 125B enclosures.
* Center punch not included
$25.00
Drill Marking Template
Weight | 3 oz |
Dimensions | 2.5 × 4.5 × 1.5 in |
Tools
Integrated Prototyping Board
Zach Omega (verified owner) –
Awesome! It makes making up a 125 box so much easier and faster! I use a fine point marker to mark the locations. Then I use a center punch with the template removed (don’t want to damage it).
It seems very well made as well.
szukalski (verified owner) –
Drill template + automatic center punch makes the build process a lot easier. Worth the investment.
willis.charlesd (verified owner) –
This jig was worth every penny. I absolutely hate drilling enclosures, but this makes it so so easy.
It’s cheap and convenient to order the predrilled enclosures from Tayda. With this you can order blank enclosures to stock up when you’re not sure what projects you’re going to build. Don’t skip out on the other jig/template for the top jacks either.
This thing made precise drilling SO MUCH SIMPLER! Every pedal builder should have one. Saves a TON of time!
