Use this template for consistent placement of top mounted jacks on 125B enclosures.
Includes two M3 x 8mm screws with M3 nuts.
$15.00
Drill Marking Template
Weight | .375 oz |
Dimensions | 2.2 × 3.5 × 0.5 in |
Tools
Pedal testing platform
Zach Omega (verified owner) –
Solid product that makes marking the input and output jacks + power jack a breeze.
Not sure why they don’t include the screws, but not to worry…I used two screws from a 125 box and they threaded themselves into the holes. No nut needed.
This takes way less time than cutting up paper templates.
szukalski (verified owner) –
Greatly improves the build process. Comes with everything you need (ie. screws). Well worth it.
andare (verified owner) –
Drilling top jacks is a cinch with this. Waiting for a 1590B version 🙂
AjiKacey (verified owner) –
I’m not sure if the newer version of this product is printed on a thinner PCB, but the gap is a little too narrow to accommodate the edge of a typical enclosure, meaning you can’t tighten it fully and, loose, it wobbles a bit. I might have to add some washers to fix that issue.
Fontelroy (verified owner) –
15 bucks well spent! I can’t tell you how many times I’ve printed off a drill template, taped it up and still had one of my 1/4 jacks a little too close to the side wall of a 125
