- Rate
- Depth
- Blend
- Shape (Toggle switch)
The company, product and service names used in this web site are for identification purposes only. All trademarks and registered trademarks are the property of their respective owners. This product is not manufactured or distributed by Walrus Audio, maker of the Walrus Audio Julia.
PedalPCB is not affiliated with Walrus Audio.
RSteel (verified owner) –
Fantastic sound and tonal options. Couldn’t be happier with build
kalebk2204 (verified owner) –
Sounds incredible. One of my favorite builds so far. Just make sure to adjust the trim pot til it sounds the best. Mine wound up being set at about the 1oclock position
Such a fantastic sounding ce2 based circuit
finebyfine (verified owner) –
Amazing chorus. The BBDs and Clock are not the easiest to find at the moment (writing in fall 2021 here) so be sure to have them lined up if you are planning on building the board right when you get it.
mp224 (verified owner) –
Ok this is my third Pedal PCB build and it came out perfect. This circuit sounds awesome, just like the boutique but without the price! Highly recommended..
szukalski (verified owner) –
Worthwhile build. Very flexible. Watch the demos and you will see what you can get. One of my favourite choruses.
Jwyles90 (verified owner) –
I was actually pretty surprised by how great this sounds! I had a Julia a while back that I sold, and this sounds identical to my ears. Relatively easy to build, so if you can find the ICs that go with it then definitely pick one up.
Locrian99 (verified owner) –
Easy build, great sound. If I had one complaint would be to mention the rate led would be always on in the build document and mark on the board which is the rate led for ease. That being said you can just hook the ground up to the 3pdt in the same location as you wired the SW pad to make it turn off…
Watch your input level, as too much volume distorts the vibrato section of this chorus pedal (this is obvious when the blend is turned up to full). Aside from that, this is one stellar chorus; certainly a standout among its competitors.
airbud (verified owner) –
Great pedal. Some wacky options, but a ton of usable stuff for both the chorus and the vibrato. I have mainly used the chorus; every time I turn it off I ask myself what’s missing from my sound. Slightly more complex build, but it wasn’t hard at all to find the BBD chip in 2024.
I would add this to the must-build list. Fun pedal that makes you want to keep playing, with both traditional and wacky sounds.
