The PedalPCB Intelligent DPDT Relay Module brings the automatic latching/momentary switching of the Intelligent Relay Bypass Module to a versatile DPDT relay switch that can be used in a variety of applications. (Gain stage switching, delay feedback, reverb time, etc)
For standard effects true-bypass switching see the Intelligent Relay Bypass Module.
Includes
- Relay Bypass PCB
- Pre-programmed microcontroller
Footswitch, relay, and other components are not included
Features
- Uses latching relay (not included) for lower power consumption
Intelligent Latching / Momentary Switching
- Tap footswitch to toggle relay OPEN / CLOSED(standard operation)
- Hold down the footswitch while the relay is OPEN to momentarily CLOSE relay until the footswitch is released
- Hold down the footswitch while the pedal is CLOSED to momentarily OPEN relay until the footswitch is released
