- Harmonics (Toggle switch)
- Bright (Toggle switch)
- Low (Toggle switch)
- Runs on standard 9VDC pedal power
The company, product and service names used in this web site are for comparative purposes only. All trademarks and registered trademarks are the property of their respective owners. This product is not manufactured or distributed by 29 Pedals, maker of the 29 Pedals EUNA.PedalPCB is in no way affiliated with 29 Pedals.
Dethmoth (verified owner) –
Super easy to build and sounds just like the Euna I had previously, to my ears at least. Best part is it takes up half as much space
jjjacksonistheman (verified owner) –
meh. i guess it’s supposed to be totally transparent. the effect of high/low/harmonics switches are really subtle. i’m still skeptical that it actually does anything. but, at least, it doesn’t seen to make anything in my signal path sound any worse.
I L-O-V-E this pedal! I put it at the very front of my signal chain and it makes all of the other pedals on the board sound like they were meant to. I heard the EUNA described as “taking a blanket off of the amp”. I couldn’t say it any better! I’ve now built this pedal twice; once for me. Once for a friend. We’re both 100% satisfied.
It’s ALWAYS on the board and it’ always ON.
Now, if we could just get a 29 Pedals OAMP style PCB…
Killstring (verified owner) –
So, I effed up this build about every way that you can. And yet, it (eventually) worked, and it sounds great. Does the thing, and I actually really enjoy the little hype switches.
takyon (verified owner) –
Smooth build all around. Can’t compare to the original, but it does add something special to your sound. You won’t be able to turn it off once it is in your rig. It is a subtle effect when used with a short pedal chain, but shines when using a ton of other pedals. The harmonic switch can be a little much at times, but is a great studio tool.
I used an electro for c6 because it is all I had, but I don’t think the audience will ever know.
